Desmoquatro question for you experts out there.
When the forward cyclinder is at TDC using indicatior on the piston, all the cam markings are lined up. Certer timing belt pully is lined up to mark on cases, and the cams all line up.
When the vertical cylinder is at TDC, the cam markings are are all off 20 degrees or so. Is this correct or is there something wrong with my timing?
I was checking my cam clearances and came across this and it doesn't make sense.
Thanks. Long time engine builder but first time inside a desmoquatro.
