also i disabled my exhaust valve today which was more of a pain in the ass than it should've been. first off, why does Ducati (or other companies for that matter) use "quick-connects" that are everything but ****in quick to disconnect. I'm pretty sure it took me over 20 minutes to disconnect that little motor. There's barely any space to find my hands in there, and of course all their wiring is exactly the length it needs to be, not an inch more!! And then those 2 little metal pipes that the cables go through next to the exhaust are impossible to take out without removing the entire exhaust and who knows what else! One of the bolts holding it on is behind the frame and next to the exhaust pipe so there is no space for any tool, or your hands to go through. I ended up getting really pissed and grabbed it with a pair of pliers and broke it off the bolt (thankfully it is just a thin piece of sheet metal)!!
Oh and everything seems to work fine, I got no error code after disconnecting it. I have the stock ECU, but it was flashed and remapped.
