try it and you'll be suprised it works. I sure was.
On my 1098, without the servo 'posts',
the servo wheel spins for a while,
then the Yellow CEL dash light comes on.
If I then cycle the power, the CEL does not come on.
But it will return on the next normal power up.
OIO98, Did you remove the cables from the valve end,
cycle it once, then remove the cables completely?
GSXR1K - I had trouble getting the simple flat piece of metal to work.
And when it finally did, it eventually rotated on the shaft.
Bolts screwed into the servo wheel right at 'the corners' work well for me.
All,
Of course, if the 'Zard' magic cable removal method works,
we need to figure out why and how, and be happy.
Perhaps its a one shot deal to remove the cables and not bump the servo.
