Just bought a ducati. Had it for 2 months, started to show signs of engine issues: engine jerks when i rev above 4000rpm. Send in to my mechanic. Changed the fuel pump, found a leak in the valves. Did top overhaul for this.
Had it running for a week. Now engines seems to face problems trying to rev especially in the 4000-5000rpm. Engine splutters and it will rev above 5000rpm but speed doesn’t pick up.
gonna check the plates next.
running stock exhaust and no modifications
I do not know the running spec as per book, but the guess is anything around 150 psi or more is a working number. Both should be close to even numbers or syncing is going to be a problem is one.
So the numbers read a working performance number (175-160 psi). Out of performance is 159 psi, so do not cry is runs weak. 145 psi means it's out of spec give or take a pound. That says 145 or under, is rebuild time.
