In the process of building a case up Ducati TT1 at the moment. Using a 600SL engine as the foundation and turning it into a hi-comp 750cc. Ceramic bearings throughout, Carrillo rods, balanced crank, NCR cams, bigger valves, all lightened internal gearing, 750 dry clutch, Omega 'Rutter' replica pistons, oil cooler, 40mm carbs
For the roller we are using a Verlicchi TT2 frame, so cantilever version, 40mm '89 Sport forks with gold valves and 17" Marvic magnesiums, Ohlins rear shock, P08 brakes, floating discs, TT2 rear sets, stainless TT1 reverse cone exhaust.
Looking forward to it
In the background is another one waiting .... I need to restore a TT2, again Verlicchi TT2 frame, with a 650SL engine, 36 Del Orto's, 35mm adjustable magnesium forks and triple, 18" rear 16" front (of a '80s Suzuki Katana, will need to source a less offence set up : ) should be relatively straight forward as I am leaving the engine relatively stock, just a freshen up.
And on eBay I have listed the 3rd TT2, simply no time to finish it (have a 2v 1100DS project I am finishing) This one has a Roy Thersby TT2 replica frame, verlicchi swing arm stock 600SL engine, Pantah wheels, etc. Hopefully it will find a happy home soon. It only need TT2 front bodywork and tank to looks period correct, currently has F1 look about it.
