Hell o All!
I hope someone can point me in the right direction before my 2005 749 breaks my heart.
My bike was throwing me injector 1 and 2 error codes at the same time. Replaced ECU with stock used one from ebay, (EU version, not US version). Flashed ECU and ticked off immobilizer. Now she turns over and will fire with starting fluid, but still no fuel pump action. replaced fuel pump and filter. I'm getting ECU error code 37.3. Have Red key, original black key and aftermarket key with transponder in the key. Following service manual instructions for reprogramming the keys, but I'm not seeing the 30 second count down when I put in the red key. Funny thing is that if I run the reprogramming procedure, I get the red shift led light pattern saying I reprogrammed with 3 keys but the program didnt take. when inserting the second black key, the dash light up sequence is a little different than when I insert the first two keys. Why am I not getting the 30 second count down displaying? Why isnt the fuel pump running? Why will the bike fire but not start when I squirt her with starting fluid? What should I check next? Has anyone ever had this problem?
