1 - 2 of 2 Posts
Hi all. Been having an issue with my 2010 1198s (8,500) miles) stuttering in second gear, like the DTC is active, only problem it does this when the DTC is off or on and DTC can be set any any setting 1 - 8. This only happens in second gear while accelerating moderately to aggressive to WTO.
I have not had this happen in any gear, just second. It is usually a quick double stutter then you get all the power you want. Normally happens before 5500 RPM. Any ideas?
? That souns difficult to diagnose Electronic gremlins ? But just maybe your air filter, naaaah , im thinking if its been good up till 8000km maybe an injector blockage wouldnt hurt to run an injector cleaner in your fuel for a couple of tanks. Id eliminate the easy things first
1 - 2 of 2 Posts
