Technical specification
Engine
TypeNew Testastretta 11°, L-Twin cylinder, 4 valve per cylinder, Desmodromic, liquid cooled, magnesium valve covers
Displacement937 cc
Bore x Stroke94 x 67,5 mm
Compression ratio13,1:1
▂Power83.1 kW (113 hp) @ 9000 rpm
▂Torque97.9 Nm (72.2 lb-ft) @ 7500 rpm
Technical data referring to power and torque was measured on an engine test stand at Ducati.
Fuel injectionMagneti Marelli electronic fuel injection system. Throttle bodies with full Ride by Wire system
ExhaustSingle stainless steel muffler with catalytic converter and two lambda probes.
Transmission
TOP
Gearbox6 speed
Primary driveStraight cut gears, Ratio 1.85:1
Ratio1=37/15 2=30/17 3=28/20 4=26/22 5=24/23 6=23/24
Final driveChain, Front sprocket 15, Rear sprocket 43
ClutchSlipper and self-servo wet multiplate clutch mechanically operated
Chassis
TOP
FrameTubular steel Trellis frame
Front suspensionOhlins fully adjustable 48mm usd forks
Front wheel3-spoke in forged light alloy 3.50x17
Front TyrePirelli Diablo Supercorsa SP 120/70 ZR17
Rear suspensionProgressive linkage with fully adjustable Ohlins monoshock. Aluminium single-sided swingarm
Rear wheel3-spoke forged light alloy 5.50x17
Rear tyrePirelli Diablo Supercorsa SP 180/55 ZR17
Front wheel travel185 mm (7.3 in)
Rear wheel travel175 mm (6.9 in)
Front brake2 x 320 mm semi-floating discs, radially mounted Brembo monobloc callipers, 4-piston 2-pad, radial pump with adjustable lever, with Bosch ABS as standard
Rear brake245 mm disc, 2-piston calliper, with Bosch ABS as standard
InstrumentationLCD display with Dot Matrix area
Dimensions and weight
TOP
Dry weight178 kg (392 lb)
Weight data refers to the dry weight of the motorcycle without battery, lubricants and coolants for liquid-cooled models.
Wet weight (KERB)201 kg (443 lb)
Kerb weights indicate total bike weight with all operating consumable liquids and a fuel tank filled to 90% of capacity (as per EC standard 93/93).
Seat height890mm (32.0in)
Wheelbase1,498 mm (59 in)
Rake25,5°
Trail104mm (4.1In)
Fuel tank capacity16l - 4.2gallon (US)
Number of seatsDual seat
Equipments
TOP
Standard EquipmentRiding Modes, Power Modes, Ducati Safety Pack (ABS + DTC), RbW. Marchesini forged rims, tapered aluminium handlebars, carbon fibre components: front mudguard, cam belt covers. Ready for anti-theft system, heated grips, sat-nav
Warranty
TOP
Warranty24 months unlimited mileage
Maintenance service intervals15,000 km (9,000 mi)/12 months
Valve clearance check30,000 km (18,000 mi)
Ducati
Engine
Displacement937 cc
Transmission
TOP
Gearbox6 speed
Chassis
TOP
TOP
Rake25,5°
Trail104mm (4.1In)
Equipments
TOP
Warranty
TOP
Ducati
