21 - 39 of 39 Posts
Anyone know if the innards from an 848 swingarm (hub and axle etc) will fit into a 916 swinger?
And vise versa?
Thanks
Discussion Starter #22
848 hub is a larger diameter, hubs are not interchangeable.
Axle is the same.
Drive plate is the same.
Sprocket is the same.
Caliper hangers are not interchangeable because the locking slot is in a different place. Adaptable.
Axle is the same.
Thanks, what do you have to do to the hanger?
I'm hoping to use one to fit an 848 caliper, disc and speed sensor to a 916 swinger.
Cheers
Discussion Starter #24 (Edited)
Use a hypermotard hanger, it's a straight swap and you can use the 848 rotor, caliper and speed sensor. It's more difficult to make the 848 hanger fit the 996 s/arm than it is to make the 996 hanger fit the 848 s/arm. You can't use a 996 hanger with a 848 rotor.
can you show where the "strategic" machining of the 996 rocker needs to occur?
also, for the 30mm offset triples, will the steering tube from all the 848/1098/1198 series fit the 916/748/996/998 series?
Nichol's site shows that they all seem to work, but just confirming!
Discussion Starter #26
Why, are you going to make your own adapter?
The 848 steering tube and stem are longer than the others.
Please excuse my ignorance... But why didn't you just use the 848 wheel/ hub/ brake/ etc assembly as opposed to exchanging it all for the 996 bits?
Bike looks badass, and you should be congratulated on your work here. It's guys like you who keep our race (humans) evolving :)
EB.
hmmmm....nobody left here online who has this conversion in use? :confused:
what's a starting point for the rear shock spring?
just like it comes on 848/1098 ?
or softer or stronger?
Hi wind walker
i have just joined after reading about your experience
would like to buy the top rocker mount if you are still doing these
is their a private message set up on this site save every one being involved
Regards Dion
i was trying to get either these made or the custom rocker that was designed via another forum and didn't have much interest.... we need like 8+ people....
Hi is the person Wide Walker no longer on the site?
what is the modification this other site you mentioned made?
Has any else used the one Wide Walker made?
did it work ok ? does anyone have experience with this other adaptation you mention
Thanks Dion
pics
The first pic was the first prototype I fitted. First 2 were junked as the learning curve grew. All other pics were taken with the final design fitted. I will make a better effort of the "squashed" pipe now that everything works properly. The ride feels pretty good, difficult to really feel a difference in the springing. Will know more after I fit the offset triples and get to the track. Feel free to as questions. Cheers.
21 - 39 of 39 Posts
