848 front forks/fender-painted for track bike/axle/DP titanium Brake Pads/Spiegler Steel braided lines(black with red fittings)/caliper bolts this is everything but the calipers for a front end swap
999 Rear wheel with bushings/ black 10 spoke marchesini
999 Wiring Harness w/ECU (Complete Harness)
999 Battery Tray with Voltage regulator
999 Race tail/w seat and carbon fiber exhaust cover (Scratched but no cracked)
Rear shock linkage w/ ride height
All bolts/banjo bolts/washers/spacers/some dzuz clips/brackets/rubber mounting straps
throttle tube
Brake/clutch reservoirs with lines
Stock steering damper
right side ram air duct (coolant reservoir side)
05 999 throttle bodies with fuel injectors
all sensors
two Race fairing stays (both broken but can be fixed) one is moto holders/other is vortex
two steering stem eccentrics (one oem) one is red by sling shot racing
black sprocket cover
999 kickstand with kickstand switch
steel braided rear brake line (grey)
ignition starter (right side clip on)
clutch side choke
999 ignition/gas cap (have key but needs new one but still works)
clutch push rod
horn that goes beep.
Stock Sprocket set for 999. Excellent condition (Were new and then swapped for vortex)
999 Gas tank with dent on top left but no cracks/leaks
999 Fuel Pump
Discussion Starter #2 (Edited)
I've got a race next month at Putnam Park for the AMA Amateurs and I need to unload these parts to free up some funds. :)
Help a racer out :)
Forgot the rear wheel
