A friend of mine who also has a 1198 had the lower oil cooler line loosen up and he didn't notice until he got to work in the morning about a 60 mile ride. His rear tire had oil on it and a puddle started to form under the bike. I helped him tighten everything back down and then went to local dealer to pick up some oil as it was below the lowest marker.
I had to run to the meeting so he supposedly topped it off and then put the fairings back on. I hadn't seen him since last week until last night when he came to me telling me that he added too much oil. Evidently oil had gotten into the airbox and now when you start the bike white smoke is coming out of the box. He drained out the excess oil from the engine but he airbox is still smoking up.
Also since this issue his bike will not idle. You can start it and if you hold onto the throttle it will run and ride but as soon as you release the throttle the bike will sputter and die. No codes are coming up nor is a check engine light coming on.
Any suggestions. I told him to take it in as it is close to needing its next service anyways or anyone know a good mechanic in the SoCal area near Pomona?
