My 96' CR sat for a few years leaving the front brake dragging excessively. This spring I fit new pads, EBC rotors, cleaned the calipers/seal grooves, pistons and bled everything.
The brakes work well but still leave the rotors hot after a ride. With the front end raised I get about 1 1/4 rotation with a hard yank. Both rotors seem like they are the same temp after a ride so it would seem the pistons in both calipers are not retracting correctly.
Another weird thing is brake feel. At the lever I have a very light pull until the last bit of travel, which is firm and abruptly stops the bike. This might be normal for all I know, but linear it's not. In addition, before every ride I have to pump the brakes to get pressure.
To me it seems like the pistons are not hanging up in the seals. Could it be the master cylinder? What else should I check?
Thanks
Thanks
