Does anyone know if 749/999 front brake calipers will bolt straight on to 996 forks? Is the offset and disc in the right place?
Thanks.
Thanks.
Do you mean the non-radial 65mm ones right? Yep, they fit totally fine, it's the same design. Only the R model 100mm offset radial mount calipers won't fit.
