Turn the screw on the bottom of fork to increase your compression dampening if you have the stripe model. If not then you will have to swap to a slightly thicker fork oil. The regular model I test rodes forks were setup for in town and beginner use but slowing the suspension both rebound and compression make a huge difference in how springy/pogosticky it is
