I asked the seller if they could confirm if it would work for the 848. They said they have only confirmed the 1098 and 1198. I know the 848 wheels are different..
They said if the 848 opening was 30mm it should work. Then again I'm not sure I "need" this as I have changed the front several times with the bike fully suspended off the ground, put it on the ground rock it forward and back before I set the pinch bolts and I've never had a problem..
Any thoughts comments suggestions?
Ducati 1098 1198 Front Wheel Axle Alignment Tool Street | eBay
