SOLD Ducati 848/1040 track bike $12,000
Recent service, valve inspection, belts, suspension fluids, coolant, oil, brake and clutch fluid, new Pirelli supercorse pro slicks, , ready to rock!
ENGINE
 Wells Tuned and built motor, 1198 main bearings, 1098 cyl, Pistal Pistons, Carrillo Rods, Balanced/polished/knife edged crank (Ben Fox), Ported/polished Intake and Exhaust, Serdi cut seats,ceramic belt bearings, shaved oil pump, custom water pump(less drag), 156 rear wheel horse power. Using DP 1198 S Ecu with TuneBoy tuning.
 Speedymoto Water Pump Housing
 DP Dry Slipper Clutch Conversion
 1098 throttle bodies (includes 848 T-Bodies and various intake stacks)
 PiperCross Air Filter
 Full Termignoni Exhaust with New, new -style Mufflers
 Woodcraft Clutch Cover
CHASIS
 2009 Frame, clean title
 Ohlins 803 FRG Forks, Fresh service/new seals 1.0 nm springs
 Ohlins TTX shortened Rear Shock 110nm
 Kyle Link, Copy of DP race Link (rear suspension)
 Sato shortened ride height adjuster
 Ohlins Steering Damper with Kyle Mount
 Kyle 30mm Offset Triples (53/56,with adapters)
 MotoHolders front fairing stay
 Motoholders Rear Subframe, with custom crankcase breather/catch tank
 OZ Forged Alum Wheels
 Yoyodyne Quick Change 520 Gearing w/new sprockets
 New 520 DID Chain
 Armour Bodies Race Fairings, New Paint 1098R scheme
 Large Intake Runners
 DP Carbon Under Tank Panels
 Woodcraft Clip-ons
 Quick Throttle and cams, Yoyodyne
 Domino Kill/Start Switch, Yoyodyne
 Brembo Race Brake Master, folding lever
 Brembo Race Clutch Master, with clutch pressure switch
 Spiegler Brake and Clutch Lines
 Brembo T-Drive 320mm Rotors
 Woodcraft Rear Sets, with spares
 HM Quick Shifter
 Brembo M40 Monobloc Front Calipers
 SpeedyMoto Axle sliders, front and rear
 DP Neoprene Racing Seat
 Saldana Custom Race Radiator and Silicone Hoses
 Quick Release Fuel Cap
 Fast by Frank Tank Mount
Can’t begin to estimate how much time and money went into this build! The bike is flawless and performs extremely well. It is more bike than I can currently appreciate. For $1500 more I will include all the street hardware and bodywork, the upper and tail section off a 1098R, Carbon belly pan from the R, side panels, 848. I traded my upper and tail section with a friend who got a hold of the R stuff and then wrecked his 1098 S before he could install. I have all the items that came off the street bike, except the stock wheels and stock brake calipers (helped out more friends). You will also get all the stock engine internals, suspension, clipons, masters, rearsets, steering stem, subframe, etc, you name it. I have three large boxes of original 848! Local Pick Up May be Nec.
Contact Akkutz at AOL dot Come for questions. Thanks!
