1 - 15 of 15 Posts
S-O-L-D
Thanks Paul !
( new member )
If you are reading this you know all about the outstanding performance precise handling and stunning design of the 848 Ducati EVO, no need to elaborate on its outstanding Specs. ─
This build takes an already amazing motorcycle completely over the top with additional Gold Anodized Titanium, Glossy Carbon Fiber and a long list of Performance Part Upgrades ─
It was slowly and meticulously built over two years with no need to rush since I had other bikes for daily rides ─
Please do not waste your time or mine unless you have the financial resources and blessing of your significant other for purchase of such a motorcycle ─
This Ducati 848 EVO has "the best of everything" and no time or expense was spared to create the retina melting jaw dropping bike you see here ─
Look closely at the detailed pictures ─ The more you look, the more meticulous attention to detail you see which continues
under the bodywork with even more Gold Titanium and Carbon Fiber ─
Turns heads everywhere it goes ─ The ultimate blend of high performance and Italian industrial artwork ─ Pure Desmodromic Eye Candy !
─ go ahead --- Google "Desmodromic Eye Candy" and see what comes up... ;)
It would look great sitting in your living room, man cave or impressing clients in your corporate front lobby however this motorcycle was created to run and handle like the precision canyon carving tool it is ─
This special build Ducati 848 required well over $20,000.00 in materials and time to create as you see it here ─
I will list the parts which it took to assemble this jewel, the bike YOU would create
if you had the time and resources is right here waiting for a new climate controlled home ;
.... no assembly required
PRICE REDUCED TO: $13,400​
2012 DUCATI 848 EVO PERFORMANCE PARTS ─
WERKES PERFORMANCE EXHAUST w/ REMOVABLE db KILLERS ─ SPECIAL ORDER COMPLETELY CERAMIC COATED STEALTH MATTE BLACK to MATCH MOTORCYCLE ─ $1506.00
DUCATI EXHAUST PIPES CERAMIC COATED INSIDE and OUTSIDE MATTE BLACK to MATCH EXHAUST ─ $210.00
CONSTRUCTORS RACING GROUP ( CRG ) RC2 BILLET FULLY ADJUSTABLE 'SHORTY' BRAKE and CLUTCH LEVERS w/ REPLACEABLE BLACK DELRIN TIPS ─ $196.00
DRIVEN RACING 'D'-AXIS REVERSE GP SHIFT BILLET REAR SETS with DELRIN TIPPED
GP PEGS and FOLDING SHIFT / BRAKE PEDALS ANODIZED BLACK and GOLD ─ $615.00
THESE REAR SETS ARE ADJUSTABLE IN INFINITE WAYS
PODIUM RACING BILLET ALUMINUM SHIFT LEVER ANODIZED BLACK ─ $42.00
COX RACING RADIATOR and OIL COOLER PROTECTION GOLD SCREENS ─ $148.00
HYPER_PRO RACING REACTIVE SAFETY CONTROL ( RSC ) LINEAR STEERING DAMPER ─ $365.00
OHLINS TTX-36 MK II FULLY ADJUSTABLE COMPRESSION and DAMPENING REAR SHOCK with HYDRAULIC PRE-LOAD ADJUSTOR ─ $1480.00
TPO TITANIUM SWING ARM PIVOT ROD ( Hollow ) and Ti NUT ─ $250.00
TPO TITANIUM REAR SHOCK ROCKER PIVOT PIN ─ $50.00
TPO TITANIUM UPPER SUSPENSION SHOCK ABSORBER LINK PIVOT PINS ─ $32.00
TPO TITANIUM LOWER SUSPENSION SHOCK ABSORBER LINK PIVOT PINS ─ $38.00
DYNOJET POWER COMMANDER PCV TUNING MODULE and O2 OPTIMIZER SENSOR MODULE
CUSTOM MAPS and TUNING SOFTWARE INCLUDED ─ $380.00
An afternoon spent Dyno Tuning with Mark Sutton owner of the "DucShop" Atlanta, Ga. ─ $250.00
Dyno printout showing 118.40 / 58.23 Reliable / Repeatable Rear Wheel HP / Torque ─
SATO RACING REAR SUSPENSION BILLET RIDE HEIGHT ADJUSTOR ANODIZED GOLD ─ $79.00
CNC RACING 30mm CLUTCH SLAVE CYLINDER ANODIZED GOLD w / CARBON FIBER INSERT ─ $185.00
PURE DUCATI "BI-POLE" RACING SEAT ─ $345.00
MOTOVATION BILLET REAR SPROCKET CARRIER COVER ANODIZED GOLD ─ $165.00
DRIVEN RACING REAR SPROCKET and CARRIER ANODIZED BLACK +1 TOOTH ( 40T / 520 ) ─ $287.00
FRONT SPROCKET -1 TOOTH ( 14T / 520 ) ─ $35.00
EK 520 MVXZ QUADRA X-RING GOLD CHAIN ─ $155.00
TPO TITANIUM FRONT WHEEL AXLE NUT ─ $30.00
TPO TITANIUM REAR SPROCKET SIDE 12-POINT 41mm AXLE NUT ─ $60.00
TPO TITANIUM REAR WHEEL SIDE 12-POINT 46mm AXLE NUT ( undercut for additional weight savings ) ─ $76.00
TPO TITANIUM REAR SPROCKET CARRIER 12-POINT BI-HEX ( M8 ) NUTS ─ $57.00
TPO TITANIUM REAR SPROCKET COVER 12-POINT BI-HEX ( M10 ) NUTS ─ $60.00
CRG ARROW FOLDING BAR END LEFT MIRROR ANODIZED BLACK─ $104.00
RHINO BAR BILLET END COUNTERWEIGHTS and MIRROR MOUNTS ( L & R ) ANODIZED BLACK ─ $69.99
BILLET GP STYLE QUICK RELEASE FUEL CAP ANODIZED GOLD ─ $100.00
PURE DUCATI BILLET OIL FILLER PLUG ANODIZED GOLD ─ $47.00
DZUS UPPER BODY PANEL QUICK RELEASE FASTENER KIT ( BLACK ) ─ $113.00
DZUS LOWER BODY PANEL QUICK RELEASE FASTENER KIT ( BLACK ) ─ $113.00
BILLET FRONT TRIPLE TREE STEERING STEM NUT ANODIZED BLUE ─ $49.00
DUAL 80 WATT HID LIGHTING 6000 Kelvin Temp ( Bright White ) ─ $185.00
RED LED PARKING LIGHTS ─ $
CUSTOM BUILT SUPPLEMENTAL INTERNAL TAIL MOUNTED RUNNING,
BRAKE and TURN SIGNALS with ULTRA-BRIGHT ASTIGMATIC LED BRAKE LIGHTING ─ $380.00
Will include extra Red Dual Running/ Brake LED Bulbs and Yellow Astigmatic Lens LED Bulbs for this hard to find lighting
FRONT FAIRING FLUSH MOUNT MIRROR BLOCK-OFF / LED TURN SIGNALS ─ $25.00
INTEGRATED LED SEQUENTIAL REAR TURN SIGNALS and BRAKE LIGHT ─ $85.00
COMP WERKES FULL TILT BACK LICENSE PLATE RELOCATOR KIT with LED PLATE LIGHTING ─$174.00
SATO RACING SUB- FRAME MOUNTED HELMET SECURITY LOCK ─ $116.00
SATO RACING BILLET HOLD DOWN HOOKS ANODIZED GOLD ─ $155.00
TPO TITANIUM 32mm FRONT DRIVE SPROCKET NUT ─ $24.00
TPO BILLET FINNED OIL SUMP PLATE OIL COOLER ANODIZED GOLD ─ $28.00
ZERO GRAVITY TINTED WINDSCREEN ─ $120.00
SHORAI LFX LiON DEEP CYCLE DURATION ULTRA-LIGHT BATTERY ─ $145.00
BILLET FRONT AXLE PLUG ANODIZED GOLD ─ $23.00
BILLET FRAME PLUG SET ANODIZED GOLD ─ $80.00
2012 DUCATI 848 EVO CARBON FIBER PARTS ─
CARBONTECH FRONT FENDER ─ $177.00
CARBONTECH REAR FENDER ─ $176.00
PURE DUCATI CARBON FIBER UNDER TANK SIDE PANELS ─ $380.00
CARBONWORLD FRONT SPROCKET COVER ─ $90.00
CARBONWORLD CARBON CLUTCH and BRAKE RESERVOIR FLUID SUPPORT BRACKETS ─ $79.00
CARBONWORLD CLUTCH, BRAKE and REAR MASTER CYLINDER RESERVOIR COVERS ─ $145.00
OUTER CARBON EXHAUST HEAT SHIELD ─ $67.00
CARBON LCD DISPLAY INSTRUMENT PANEL BEZEL ─ $84.00
CARBON FUEL TANK KEY GUARD ─ $79.00
PURE DUCATI GEL COATED CARBON FUEL TANK BELT BUCKLE GUARD ─ $32.00
BRAND NEW PIRELLI DIABLO ROSSO CORSA
FRONT // REAR TIRES MOUNTED and BALANCED w/ BLACK BALANCE WEIGHTS
TITANIUM FASTENER PARTS ─
Virtually every fastener used for external Engine Cases, All Bodywork, Carbon Fiber Covers, Front Carbon Fender, Rear Carbon Fender, Frame, Sub-Frame, Entire Exhaust System, Rear Sets, Shift and Brake Linkage, All Carbon Brackets, Clip-ons, Bar End Balance Weights, Front and Rear Brake Master Cylinders, Front and Rear Brake Slave Cylinders, Front and Rear Brake Calipers, Front Brake Disc Rotors, Upper and Lower Fork Triple-Tree Brackets, Front Forks, Steering Damper, Rear Single Sided Swing Arm, Front Suspension, Rear Suspension, Rear Suspension Linkage and Fastening Nuts, Bolts, Washers, Pins and Steel Fasteners have been replaced with Gold or Dark Blue Anodized 6AL-4V ( Grade 5 ) Titanium Fasteners ─
Far too many individual Titanium Fastener Parts to list here; well over $2000.00 worth...
I will send the serious buyer a detailed Excel Spreadsheet of Titanium Fastener locations, fastener sizes, part numbers, gram weights and total weight ─
Titanium, Carbon Fiber and other part weight reductions total over 14.5 Pounds including Ultra-Light Lithium ION Battery ─
MISCELLANEOUS INCLUDED ITEMS:
"PIT BULL" brand REVERSIBLE WHEEL STAND w/ Front and Rear Wheel 'D' and 'DR' HOLLOW AXLE PINS ─ $229
SPECIALLY MACHINED ( by Mfgr. ) STAINLESS STEEL 1/2” DRIVE 41mm and 46mm 12-POINT SOCKETS for both REAR WHEEL SIDE and SPROCKET SIDE HOLLOW AXLE 12-POINT TITANIUM NUTS
REAR WHEEL AXLE CHAIN ADJUSTOR TOOL
SHOP MANUAL .pdf
DYNO JET CUSTOM FUEL MANAGEMENT MAP FILES ( Tuned ) and TUNING SOFTWARE CD
BILLET UPPER FORK MOUNTED BRACKET and FUSED 12v POWER SOURCE for MOUNTING RADAR, CAMERA, or ?
HIDDEN AUXILIARY SWITCHED and FUSED POWER SOURCE w/ LED LIT STAINLESS STEEL PUSH BUTTON INSIDE LOWER COWLING ( not used at this time )
THIS MOTORCYCLE IS ADULT OWNED and RIDDEN with RESPECT for DUCATI RUN-IN MILEAGE and RPM RESTRICTIONS ─
NEVER RACED, ABUSED, DROPPED, ' WHEELIED ', ' STOPPIED ', BEEN IN ANY "ACCIDENT" or LOANED to any OTHER PERSON ─
OIL and FILTER CHANGED EVERY 1000 MILES w/ DUCATI RECOMMENDED MOTUL 300V 4T 15w50 FULL SYNTHETIC OIL ─
RADIATOR FLUSHED and REFILLED with DUCATI RECOMMENDED COOLANT EVERY 2000 MILES ─
CLUTCH and BRAKE FLUIDS RECENTLY PURGED and REPLACED ─
ALL ENGINE, TRANSMISSION, BRAKING and SUSPENSION MECHANICAL PARTS and ELECTRICAL SYSTEM / SWITCHES WORK AS THEY SHOULD ─ No Issues, No Excuses ─
FUEL TANK HAS BEEN REPLACED under DUCATI WARRANTY FUEL TANK RECALL ─
NO DRIPS or LEAKS OF ANY KIND ─
ZERO DEDUCTIBLE and TRANSFERABLE EXTENDED WARRANTY
to March 29, 2018 ─
FRONT and REAR TIRES MOUNTED and BALANCED w/ BLACK BALANCE WEIGHTS
BRAND NEW DUCATI FRONT WHEEL and FRONT WHEEL BEARINGS
( dealer minutely scratched front wheel bead when changing tire - it was replaced immediately )
Dyno Tuned by Mark Sutton ─ owner of the “DucShop” in Atlanta, Ga.
Specializing in Ducati and other Exotic Motorcycle Marques
Documented 118.40 H.P. ─ 58.23 Rear Wheel Torque
Did I mention this is a fantastic motorcycle for the performance and styling purist ?
Pure Eye Candy ! Make it yours
Buyer responsible for Local Pick up or Transport / Shipping
Have Clear, Clean, no Lien Tennessee Motorcycle Title in Hand, ready to complete Sale Immediately but not interested in
Trades for other motorcycles or "Charity Offers"...
I Thank you in advance for your time in reading this long ad
PM with any questions you may have or additional detailed photos you may require to make an informed buying decision​
Damn what a great looking ride. I wish this had been on the market when i bought mine. A guy with the same name lives directly behind me down in Tampa and if it were him I'd smack him just for general purpose.
Good Luck with the sale.
Discussion Starter · #13 ·
Thanks for the compliments -
Wish you were in "the market" as well, I'd like to start my next project....
It really is a stunning machine which performs as well as it looks. Pictures only do it partial justice, even better up close where you can see all the details and hear the throaty sound of authority it belts out when you twist the wick.
Discussion Starter · #15 ·
S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D S-O-L-D
Yeah, It's gone....
Now on to the Aprilia RSV4 Project.....
1 - 15 of 15 Posts
