1 - 20 of 24 Posts
I have a 70 mm Termignoni full exhaust system for Ducati 848/1098/1198. I also have a tuned race ecu designed for the exhaust to be used on a Ducati 848. The exhaust does have two small dings from going down at the track but they have no effect on performance at all. The exhaust system has full flow and works perfectly. Included is a carbon heat shield. $1200 or best offer
Braking wave rotors. These can be used on Ducati 749/999/848 These are 320mm rotors. $375
Located in Bridgewater, NJ. My name is Adam and my phone number is 908 875 7758
Man I'm looking for a race header pipe to make a full system. Is the race ecu different then the ducati performance ecu that comes with slip ons?
The OP needs to state which model the system is for, as they are different between the various models.
Different exhaust port sizes, and specific ECUs for the model.
And yes Garrett - the ECUs are different for the full system compared to the slip-on-only ECU.
And the 848 has 320 mm rotors where the 1X98s have 330 mms (but the smaller ones can be used on the 1X98s without the spacers).
Just to help clear the confusion on the exhaust.
Pat is correct if you have an 08-09 848 as the non EVO 848 / 1098 have the same size exhaust ports.
But, if it is an EVO 848 then the exhaust will interchange with an 1198 but not a 1098 as the EVO 848s share the same port size as the 1198.
So the question is, was your 848 an EVO?
1 - 20 of 24 Posts
