Hello all, been a long time lurker and have done quite a bit of research and am somewhat at my wit's end with this problem of mine.
I have a 2000 748 and it's fuel lines are not prepping when I pop up the kick stand and flip the kill switch on. The engine does turn over (sounds like it's about to fire up, hear/see the clutch assembly ringing/spinning a bit). But it does not catch and actually start. Like I said, when I flip all switches on, normally I hear the fuel lines prep but it is no longer the case.
I've been researching this quite a bit and decided to buy a new fuel pump (gold cylindrical piece in the fuel pump assembly) and have replaced that and have the same issue. I inspected the low level fuel sensor wiring and visually appears to be okay, but I do not have a multimeter or much electrical know how to be able to test. I have also replaced the two fuse pieces underneath the seat at another recommendation I have seen floating around.
It may be worth noting that I purchased a new battery from autozone earlier this season, it is not the exact sizing but it started everything up fine for a couple weeks. The lights on the dash and headlights come up fine when I turn the key on still as well. Seems like all electrical is okay..
So my question is, does anyone have any recommendation on what my next course of action should be? I'm pretty antsy to get this thing back up and running as I've been missing the best time of year to ride. I'm considering calling Ducati and seeing if I can just bring the gas tank in and have them inspect the fuel pump assembly for me, but am also concerned about getting charged to all hell.
