1 - 16 of 16 Posts
So, I have got a set of Termi headers coming, but they don't have the hardware...what all do I need? Pretty sure I should be able to find most of it at a hardware store, but looking to get a head start.
How many of what size nuts and bolts...how many exhaust springs etc.
Appreciate the help.
Discussion Starter · #2 ·
Found out I need 7 exhaust springs, unfortunately I think there are only 6 on the stock system, so i will have to find another one.
I am guessing its just a short nut and bolt that join the two pipes together behind the heat shield, and maybe I can reuse the existing bolt to attach it to the frame?
What about the heat shield...does it use the same bolts, spacers and washers as the OEM triangular piece...can I just re-use those?
Indeed seven springs and it has the same bolt on to the frame.
It doesn't have the 3 point heat guard attachment, but two point instead. Reason why you get a new exhaust shield with the full-system, same goes for the springs etc.
What I meant was, can I use those bolts from the three point heat shield for the two point one?...are the bolts and spacers the same size?
Are the springs a different size from the OEM exhaust, or can I make those work?
Appreciate the feedback!
Anyone happen to have a couple exhaust springs laying around? Or know what size to order...going to be short 1 spring.
I guess its fine to run it without, maybe leave the one off the Y pipe, exhaust hangers and the frame should keep it secure till I find one.
Anybody here have extra springs laying around? I had to cross-cross the ones on my bike when I bought it because they lost their tension and were rattling away...or the previous dude straight up used the wrong ones.
1 - 16 of 16 Posts
