I'm installing a new keyless gas cap.
Which hole do I put the tube in? A or B?
A is the drain, B is the breather (as a double check, it should line up with the little rubber cap on stock cap (some Ducati's have the breather in a different position depending on the cap.) From what I can tell looking online that hose is a breather, were there no instructions in typical Italian style?
Looking at the attached photo, you may problems with the size of the stock breather hole compared to the size of that hose... (can it be unscrewed?)
Disclaimer - I've never tried fitting one of those caps... (I don't think my fuel would still be in the tank if left unattended!)
it’s not a drain hole it’s overflow / breather. Both tubes just run down to the belly pan. On the stock pan one goes out the hole in the pan. It does matter which one really..
Reactions: pahhhoul
