Im about to totally go insane here, have the two bolts holding the rearset to the frame off but cant for the life of me figure out how to get the gear lever off of the rearset/bike
any help very appreciated
Loosen the nut hat holds the length adjustment on the gearshift rod.
Remove the rearset, and (it takes a bit of manouvering here...) twist the rearset so you can see the bolt fastening the shiftrod's eyelet to the rearset. Remove that bolt.
Tip: Make sure you keep the twisting of the shiftrod to minimal, otherwise it would take a lot to readjust the length to proper length again.
At least that was how I did it.
