HI EVERYBODY
so, at the end, me and my Father did it... it has been a little more difficult that expected, but, at the end, is not that bad.
what is really worse than expected, where the Baffles... i didn't expect to find such a system of flowing fumes in the can for noise abating:
The blue circle is the Cat Converter, and the arrows... the Exhaust Flow... i can;t bhelieve that the engine has to breathe thru those things!
LETS GET STARTED
TOOLS
You just need a Drill, a Dremel with many (a lot) metal cutting wheels, and something to do leverage like a Flat Screw Driver.
1) Drill Out the Rivets around the Cap at the end of the Cans, and push down the ring that holds the end of the SlipOn like this:
2) try to pull out the cap, use a screw driver or something similar to help pulling out the cap... actually is not a cap, the cap is welded to an internal can that goes inside almost all the way to the SlipOn
If you look from the back of the extracted can, you can see the damn Baffles:
Unfortunatelly there is no other way to remove them other than cut away the can from the cap
3) With the Dremel and the Cutting wheels, cut around the can near the cap
The cap has a little tube... too little, so you have to remove it
4) cut the metal around the base of the little tube of the cap so there will be just the hole visible from the outside and nothing else as obstacle to the exhaust flow
and this is how the cap looks from the inside:
5) take away the insulation from inside the can otherwise you will blow it in the face of somebody while running:
I decided to leave the Cat converter
6) Try to fix the metal of the can to make it more straight possible before putting back the cap
Even if it's not perfect, is not big deal, the ring around the cap will cover eventual damages to the can metal
7) push the ring back in place
Now the choice is yours... you can put new rivets... i decided to put screws, they hold tighter...
the sound is awesome, as you can hear from the Video Clip:
http://www.youtube.com/watch?v=73ikmVfNngY
http://www.youtube.com/watch?v=0EcZ5NE2Fa8
I think this is a really nice way to save $2k for Termignoni... if any of you needs help doing the job... PM me and we may work something out...
REGARDS
LETS GET STARTED
TOOLS
REGARDS
