Hi Guys,
First time posting in this forum. I have a 2010 Streetfighter S and I'm switching out the 8 worn clutch rings for new ones and also the basket.
As I was removing the 32mm torqued center bolt I was expecting the hub to just come off loose in my hand but it hasn't. Instead the hub came off after leaving its back portion stuck to the center... see pic.
Question is, how do I get it off? its on there pretty solid and I tried cloth covered pliers and it won't budge or pull out.
I can't fit the hub back on in this position cos of the complicated loose rubbers inside the hub and the awkward angle.
