1 - 3 of 3 Posts
That smiley face is my desperation kicking in. Just bought a Ducati 1 month ago and feel like it's just one thing after another of bad strokes of luck.
Anyways I got this breather pipe leaking fuel and I don't know what it connects to or how to fix the issue?! Everything on the tank side was good all hoses connected and snug. No leak from fuel pump. No leak from engine top seal. Only place it's coming from is the pipe? Is it supposed to be open?
Discussion Starter #2
Doubt this makes a difference but who knows at this point certainly not I.
It's slightly elevated in the front with a wheel chock and it leaks consistently when it's on. No leak off.
Discussion Starter #3
Fixed. All those who may find themselves here with this issue some how it was a hose that came undone from the source I just followed it up and it comes from the bottom of the intake casing. Also a loose nut under the tank. Tightened nut. Fastened hose. So far so good. Time to put her back together and go for a ride. Will come back if any issues arise.
1 - 3 of 3 Posts
