1 - 7 of 7 Posts
I bought this bike for a steal because of the rock chips and scuffs in the fairings and tank, but I am looking for some help with touching the imperfections up. the chips are on the tank, the scuffs are on the fairing and the small scratch is on the rear cowl. I was wondering what the best way to do this would be? What do you guys think?
From those photos, best bet is most likely some light wet sanding and buffing.
Probably not going to get all of it out.. especially if your fingernail fails into the paint chips.
Looks like your opinions are polishing, touch-up, professional re-spray, or purchase new fairings.
I just got some touch up primer, Ducati red and clear coat from www.touchupdirect.com. It arrived today, so I haven't used it yet.
I came across paint for my yellow Aprilia Tuono and it is a prefect match. I used the touch up pen kit.
Might help with a few of those scratches....
ColorRite Rocks
Go to ColorRite and order the Color Pen to fill the damage.If you sand it down and spray over it including gloss it will peel real bad.Its either the Pen or the whole piece from scratch...I have bought damaged pieces and totally refurbished them,they came out looking new.Spare pieces are all wrapped and stored...Did all this w/ there kit...
remove the parts
mask surrounding area about an inch around the damaged area, unless you have several pits or scratches, if so then sand entire area starting with 400 then 600 grit wet sand paper, until you hit paint. use an air brush or touch up gun, spray color matched paint. wait a couple of hrs, then clear coat using air brush or touch up/detail gun.
if pits or scratches are deep I suggest filling it with a good 2 part primer. if its a deep scratch I usually fill the scratch or pit by using a brush kinda like using bondo. they're pretty much the same thing, except bondo uses more plaster which makes it thicker. when filling the scratches, dab the scrathc with a small paint brush or match stick filled with primer. let it dry then do it again. Do this a few times until the primer is a little higher then the paint. then gently sand the lump down till it is even with the surface.
then spot paint with air brush or detail gun. wait a couple of hrs ( you usually have up to 24 hrs to clear after paint is applied). then wet sand area starting with 1000 grit wet sand then, 1500, 1800, and 2000 then polish using a high quality rubbing compound. I find polishing the entire bike after with automotive headlight and glass polish works well. Polishing the entire bike will help blend the new paint.
On the other hand aftermarket fairings are pretty cheap and if you do the prep work sanding your fuel tank. A body shop will charge about 200 bills for a repaint. Probably save you alot of hassle!
I just got the pen in today, I applied it to the damage but it seems that the touchup paint is higher than the factory paint. What would be the best way to take care of that? I was thinking about using the 1000 grain wet sand paper with a cork to level it, then moving to 1500 then 2000 then putting a compound on it to remove the sandpaper scratches then if it looks good like that Ill leave it, if not ill apply clear? Does that sound about right?
1 - 7 of 7 Posts
