I think the proper USA name would be "alignment punch", but any appropriate tapered or properly sized rod would work.
"Drevel"? I like that.
Kind of like German "schmidlap" for that bit of unidentifiable "stuff" you got on your shirt.
"Alignment" that was the key missing word! Thanks for joggling my memory Marc!
And Dutch, thanks again for this great feedback. I added these two back-to-back annotations to the video starting at 4:49:
"UPDATE:
Use an alignment punch or similar tool during this step."
and:
"Place the punch inside the hole seen here on the front face of the small gear to align the teeth. The drum will come off (and go back on), MUCH easier if you do this!"
Very nice. Thank you.
Had mine done at the Dealers under Extended Warranty. November, same day I put the bike away.
Only did 60 kms on it and loved the actual real change of gears, first time every time.
Had false neutrals all the way up the box. Yuck
Was told they put the upgraded version on, whatever that means
Thought I'd join this thread.
First, thank you everyone for the great input. Marc and Charles, outstanding info and great video. I just ordered the ceramic bearing/spring kit. I'm tired of false neutrals on the track leading to dangerous situations. I had the shift drum stuck in neutral bit happen once too. So hopefully, this will take care of that once and for all.
I fitted the Factory Pro Ceramic Bearing detent kit, and am very happy with the result. I think I provided some feedback on my 'Pat's Engine Overhaul' thread.
I got it through Motowheels. All good, except for the crazy postage for such a small item in a rather large box..
As Marc S. described - the kit has a stiffer spring (2.3 mm wire, as against 2.0 mm on the stocker from memory) but reduced friction thanks to the proper bearing on the roller.
I found it makes the gearchange easier, quicker, and more positive. A real improvement. Can't remember missing a shift since fitting it (but then that didn't really happen before).
With a lighter clutch action courtesy of a larger diameter slave cylinder, plus the ceramic detent kit, gearchanges just feel 'slicker'. Riding bikes with the standard shift feels a bit 'clunky' and stiff by comparison.
BUT - yes, there's always a but.. I had difficulty removing the original mechanism. The Loctite used on there meant I had to damage the (special) pivot bolt to remove it. It was ridiculously seized with presumably a too-high-number Loctite.
So between the postage ($35 from memory..) and the stock pivot bolt (about $9 here) it wasn't such a cheap mod.
I guess they remedied this Loctite choice on subsequent models, as I've not heard mention of this issue from others. Mine is a 'vintage' 2007 model..
Pat, I can see how that special bolt could easily incur damage if an over-abundant amount of locktite was used at the factory. The torx head as you know is rather shallow... fortunately on my 09' the locktite wasn't an issue and mine came off relatively easy.
I echo everything you say about a more positive shifting experience. I consistently had False Neutrals before my Factory Pro days, but after the installation--zilch!
Jimmy, you're going to be very happy with this upgrade. I was tired of the false Ns too. The only good thing about a false N is it allows you to test your mettle under stress. I had one too many tests and was ready to move on--this kit will firm-up your shifting and make it right!
Of course I applied heat to mine also, but (as Charles noted) the inadequate small/shallow Torx engagement was already compromised by then.
The Loctite on there was unreal solid. I had to re-tap the 8 mm hole before I could fit the new one. Unfortunately this will send debris into the motor if the crankcases aren't being separated.
Maybe get in there and try removing the bolt Gr8 before you order your parts. My bolt took a week or so to come in.
And good luck! Forewarned is forearmed, as they used to say.
No doubt! I'll order a bolt up just in case. Headed to Ireland in another week on a 3 week vacay, so I'll hit up the spring when I get back. It won't be in until next week anyways.
Just a FYI for everyone: Motomfg is no longer making the wet clutch basket holder tool. There is an eBay seller in the UK that makes one and it's about $100 to buy and ship.
1) My clutch basket but needed a 30mm socket.
2) The big washer in the clutch hub was very tight on the shaft. Both removing and installing required some extra persuasion.
Waiting on clutch basket holder to finish the install. If you have a Yoyodyne slipper, you won't have some of the same large bands or washers that chuck pulled off last before the basket comes out. At least mine didn't, lol.
Great instructions chuck! You're invaluable!
21 - 40 of 44 Posts
