2007 1098 w/10k miles, shows in EXCELLENT condition. $9,500 Fresh timing belts last year and less than 1k miles ago (see more info. below) Respond to [email protected] to inquire. References to bike's condition, maintenance, and treatment upon request. See my feedback username Tractionless on eBay. Located 1.5 hours south of Orlando, FL
Selling to fund another hobby. '00 GSXR-750, for sale in other ads as well as a 2004 Ford Mustang Cobra with 32k miles, 1 of 510 built.
Other than the rear sets, exhaust from engine to cans (cans are new), CF Ex. Heat Shield, and clutch cover; the rest of the parts have max 2,600 miles on them, most much less. I have all records of mileage and date installed, mods. & service receipts, workshop manual on CD and mods.
manuals should the new owner request them.
Engine/Driveline
Fresh Timing Belts W/Cams degreed, TB's synched, Valve Adjustment, Valve Cover Gaskets & Plug Orings, Spark Plug Hole Seals, and Retuned Made 154hp/89 ft. lbs (See graph)
PCIII USB W/Dyno Derived Map
Full Termignoni Exhaust W/Gen 2 Cans & ECU.
14t Front Sprocket
Alth Quck Change Rear Sprocket W/SS Cush Nuts, CNC Racing SS Hub Nut, & CNC Black Wheel Nut.
NGK Iridium Plugs CR10EIX
R1 Throttle Tube
RK OE Length Gold Chain
Generic Open Chain Guard
Speedymoto Open Clutch Cover
Surflex Clutch
EVR Anti-Clank Pressure Plate
DP Springs (Powdercoated) and Retainers W/Titanium Bolts.
SS Breather
Cox Rad./Oil Cooler Screen
Motoletric Batt./Starter Wire Upgrade
Shorai 21ah Battery
Ported OE Temp. Sensor Housing
Corse Silicone Cooling Hoses
MWR Air Filter
SpeedoDRD Speedo Calibrator
Speedymoto Secondary Oil Filter Plate & Screws W/New Filter At Last Change.
Speedymoto SS Oil Pan Drain Plug
Rectifer/Regular Replaced by Ducati under recall.
Body/Frame
GOOD Carbon Fiber! All is either DP or Shift Tech. except Tank Sliders which are R&G, Undertail, and Tank Surround Under Key Protector.
CF Fender & Rear Fenders W/Matching Yellow Paint
CF Undertail
CF License Plate Surround
CF Windscreen W/Smoke Insert (Magical Racing $350!!) Better quality than DP or Shift Tech!
CF Dash Surround
CF Exhaust Heat Shield
Hydro Dipped CF Look Metal License Plate Bracket W/Light
Progrip CF Look Tank Pad
TechSpec Tank Grip Pads (fully removable)
Slingshot Racing Frame Plugs
CF (R&G) Tank Sliders
Generic Fully Adj. Black Levers
Adjustable OHlins Steering Damper W/Gold Mount
LED White Front Running Lights
Dual LED Headlights
Sato Rearsets
HM Superlite Quickshifter (fully automated)
Oberon Mirror Extenders
Scorpio Paging Alarm
Bar End Sliders
T-Rex No Cut Frame Sliders
TST Ind. Rear Tailight (2 mos. old)
OE Duc. Black Fender Bolts
Pro Grip Duo Density Grips
3M Headlight and Paint Protection Film
Driven Keyless Fuel Cap (OE Included in Sale)
Speedymoto Rear Tank Bracket
Luimoto Alcantara Seat Skin
Everything fully functions, no dash LCD issues etc.
Suspension/Brakes
OE Rear Suspension.
Ohlins 25mm Fork Cartridges.
DOS 30mm Offset Triple Clamps W/Tapered Roller Bearings.
Galfer Front SS Lines
OE Front Pads (Fresh)
Ferodo Sintergrip Rear Pads
CNC Racing Billet Black Front Axle Nut
TPO Full Floating Front Rotor Buttons
Galfer Wave Rear Brake Rotor
Extra's (For buyer's option most NOT included in sale)
OE Wheel Set W/TPO Full Floating Rotor Buttons, OE Front Rotors & Good Dunlop Rubber
OE Yellow Side and Belly Pan Fairings
OE NEW Front Brake Pads
TEchSpec NEW Tank Traction Pads (for alum. tank above)
Dan Kyle Ride Height Adj. Tool
T-Rex Rear Stand
SS Front/Rear Axle Nut Tools
OE Sprockets
OE Front & Rear Axle Nuts, Cush Drive Nuts
OE Rear Signals,
OE Headlight & Running Light Bulbs
OE Shock Link
OE Dash Cover
OE Tank Surround Panels
OE Seat
OE Ram Air Panels
OE Rear Turn Signals
Aftermarket Tinted LED Tail Light
Clear ZG Corsa Windscreen
I'm sure I'll dig up more odds and ends that with the package deal you're welcome to.
Nada dead stock average value is $8,800 and if the bike was dead stock it would be in the excellent value range. I'll gladly negotiate for unneded parts or switching out extras for currently mounted items (to a point).
I will gladly forward required pictures upon request to email addresses. As stated above please email responses direct to [email protected]
The Crew, all for sale. I'll keep which ever one is left.
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/Untitled_zpsb5a497f7.jpg
I have the solid yellow OE fairings as well. Different angle views start here.
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/Duc. rt. rear_zps6o3qyl7v.jpg
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/Duc lt. rear_zpsajo2ohag.jpg
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/Duc lt. front_zpsqijve3mp.jpg
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/Duc Tank_zpsd0xahfvx.jpg
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/Duc Top_zpspevz0di6.jpg
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/Duc Top 2_zps9xclqotv.jpg
Dyno
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/2_zps49ba3509.jpg
Tailight, the "inside" lights up in burst pattern. The outer ring changes to amber for turn signal, fully adjustable options.
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/New Duc Lite_zps0etkoiun.jpg
http://i179.photobucket.com/albums/w283/tractionless1/Streetbike Pics/New Duc Lite2_zpsimv1nky3.jpg
Engine/Driveline
14t Front Sprocket
R1 Throttle Tube
Surflex Clutch
SS Breather
Shorai 21ah Battery
MWR Air Filter
Body/Frame
CF Undertail
CF Dash Surround
Dual LED Headlights
Sato Rearsets
Bar End Sliders
Suspension/Brakes
OE Rear Suspension.
T-Rex Rear Stand
OE Sprockets
OE Rear Signals,
OE Shock Link
OE Dash Cover
OE Seat
OE Ram Air Panels
Dyno
