Ok Guys my bike has the plastic gas tank since 2008 and till now I don’t have any deformation issues so far (knock on wood) well anyway I just noticed inside the tank that instead of the white plastic that it used to be is starting to get yellow and also the low fuel sensor sometimes it works and sometimes it don’t (this weekend I run out of gas).
I bet is because is full of gunk of the ethanol in the gasoline and gets stuck or the gunk works as an isolator that is not letting it conduct.
Is there a chemical that I can use that I can mix it with gas to clean it and remove that gunk and hopefully remove it from the sensor?
