Hello all
I have observed the last few months, these voltages:
~13V key on before cranking
~14.5-14.2-14.3 (not very stable) after the motor starts
and after 1 minute maximum it drops to 13.5 and stays there. sometimes it increases to 13.7 with rev up but no more.
Its worth mentioning that the battery is always at 12.9-13.1 at hey on and never below, and always starts the bike normally, so it charges.
Is it the regulator? Is it normal?
(also i am having incorrect and strange behavior at idle and below 3k, worse than the normal 1098 thing, sometimes blackens the vertical plug, and i am about to get it checked at the service for that. been searching for plug/electrical issue for months but i ruled out the regulator as it was at 14.5 until 4-5 months ago)
Regulator
Save yourself some problems and change your regulator and buy a japenese regulator. You can get one for cheap on ebay. I had problems when the bike was heating up in traffic it would stall. It never happened on the track as it is getting a lot of air. Since I changed it, it has been working fine.
