Forum newbie here
I just got my first Ducati after riding Japanese bikes for the good part of the last 15 years. Its a 2010 1198s Corse with 20,600 kms. I have a few questions though,
1.) The battery voltage reads around 12.+ volts, but when i crank her from cold, she chugs 5 or 6 times like its barely able to turn over. Is this normal?
2.) My god, this thing burns my thighs! I was caught in traffic recently, and could not stand the radiating heat (temp was stable at 104 celsius), so i turned off the engine. When traffic started to move, i tried to start her, but she wouldnt crank over. Luckily the road was at an incline, so i coasted then basically bump started her on 2nd gear. Is it normal that starting while at running temp, is not so easy?
Im trying to figure out if my 2 experiences with starting is not uncommon for a Ducati, or should i be worried about my starter or battery needing to be replaced?
Thanks for any wisdom you can throw my way
