Is the lambda sensor still active with the termi slip ons installed?
Desmo Duc · Registered Joined Jan 28, 2007 · 547 Posts Discussion Starter · #1 · Jun 1, 2007 Only show this user Is the lambda sensor still active with the termi slip ons installed?
V vikingdrvr · Registered Joined Feb 4, 2007 · 166 Posts #2 · Jun 1, 2007 Only show this user It is supposed to be removed with the Termis slip-ons.
1 1098st · Registered Joined Apr 25, 2007 · 22 Posts #3 · Jun 1, 2007 Only show this user still active, only with the full system it is removed
paul sonderfan · Registered Joined Jan 22, 2007 · 100 Posts #4 · Jun 1, 2007 Only show this user vikingdrvr said: It is supposed to be removed with the Termis slip-ons. Click to expand... You are correct, sir.
D dingsnthings · Registered Joined Mar 31, 2007 · 18 Posts #5 · Jun 1, 2007 Only show this user Mines gone--plugged-runs great- no stalls--with slip-ons etc.
V vinman · Registered Joined Apr 13, 2007 · 204 Posts #6 · Jun 1, 2007 Only show this user the termi slip on system comes with a plug which replaces the sensor and also a plug for the wire harness. the sensor is removed.
Desmo Duc · Registered Joined Jan 28, 2007 · 547 Posts Discussion Starter · #7 · Jun 1, 2007 Only show this user Good deal! thanks
