More of a seep than a leak, on the left lower seam it is slightly moist. It is such a slight weep you could live with it but I want to fix it before it gets worse. I've got it all apart, put new fuel pump in, changed the filter, and swapped over fuel pump pick up.
Interior of the tank looks pretty good for 12 years old. I can't pinpoint exactly where the leak is other than the seam. Do you think it could be soldered from the inside so paint is not affected or should I seal it with something else.
I don't really want to use a liner type product because of the hit an miss mess they can make.
Thoughts?
Craig
Thoughts?
Craig
