Hi there. i just got my first bike monster 659 (2013)
about a week ago. I rode a few times without any issues but now most times after starting I have the following issue:
When it's in gear and let the lever go there is no traction what so ever. I can just let the lever go and the engine will keep on running but it's not moving.
The levers are aftermarket.
Anyone experienced the same issue.
Thanks,
Newbie
Are you saying that the clutch is slipping?
Discussion Starter #3
Yes it appears to be a slipping clutch. Few guys had a look at it but couldn't figure it out. They think it is something in between the leaver and the clutch.
Check the tiny master cylinder bleed hole in the bottom of the master's resivoir. Stick a pin or small paperclip wire in it to clear it. There are 2 holes in there, the tiny one is harder to see.
