So this are my issues
1)
every time when I turn on my bike..everything is fine. it fired up right away. The issue comes when I ride off...and start to give it a little throttle. once the RPM goes up...my lcd display backlight, front headlight, rear brake lights, turn signals..just all shut down together. But once i off the throttle, and clutch in....the lights comes back on.
my opinion is that there seems to be some kind of safety feature that my bike does to kill off all lightings when i face issues with overcharging? my battery voltage is fine.
2)
every time I clutch in, my self-diagnostic light(the little triangle warning sign) comes on. once i release the clutch, its off.
bike model: 1098
looks to be exactly the case...rectifier gone pouf...might want to change the battery while at it,they tend to go together
I'm having the same problem, headlights go out and dash lights when I put it in gear and drive off. Did you change the rectifier? If so, did this fix your problem?
