Hiya folks. I wanted to drop by and post the details of my build, which I've dubbed: "M944SS". After a string of mechanical frustrations with my M750 including a failed 900 motor swap I decided: "enough is enough". I would build my Monster from the frame up, sparing no expense which would include
having my favorite air cooled carby motor of all time fully rebuilt and blueprinted for a lifetime of performance and reliability, and exclusively use NOS OE parts as to have a "brand new" first generation carby Monster, but with the aftermarket upgrades I wanted.
Motor: '96 900ss, fully torn down to the case halves and bare heads & powder coated.
Motor/Performance/Electrical upgrades
- 94mm over bore and plating by Millennium
- crank balanced by Ducshop
- oversize Kibblewhite valve install with multi angle competition valve job, head porting with matched intakes, and motor assembly by Chris Birkle/Racing Sport Services.
- Nichols light flywheel & Electrex pulse coils
- Ricks MOSFET R/R
- Ricks starter
- Custom made 4 gauge ultra flexible battery>solenoid>starter and 2 gauge battery to motor ground wiring with Mil-spec heatshrink, Ancor tinned lugs, Blue Sea Systems cable caps, all assembled with a professional grade Grote lug crimper
- Shorai battery
- Keihin FCR 41mm carburetors
- Cosentino Engineering custom velocity stacks with K&N pods
- Ca-Cycleworks ignition coils
- Ignitech TCIP4 programmable ignition with custom map
- Ducati Performance billet oil breather/charcoal canister delete w/K&N filter
- Ducabike slipper clutch
- Oberon clutch slave
- Modified Roadracing Italia full exhaust system with Car Chemistry disc inserts & custom machined end caps
Braking/Suspension/Drivetrain
- Brembo RCS brake and clutch masters
- Matris F12 fork cartridges
- Matris M5 steering damper
- Bitubo XZE rear shock
- Brembo Goldline 4 pot calipers
- Sixity wave rotors
- FrenTubo hoses
- S&P billet suspension hoop with upgraded 316L stainless Teflon rod end bearings
- IMA MOD4 upper and lower yokes with 30mm offset
- IMA adjustable clip ons w/risers
- Rizoma rearsets
- Titanium axles and hardware
- EK Quadra-X ring chain
- Driven sprockets (14/41)
- Carrozerria V-Track forged wheels
- Pirelli Diablo tires
NOS factory parts
- NOS unstamped 2000 M600 frame
- NOS Cagiva era (black w/lil elephant head
) belt covers
- NOS switchgears
- NOS lockset; ignition, tank, seat
- NOS fuel tank & seat cowl
- NOS engine covers/clutch side machined/vented
- NOS swingarm end caps and sliding blocks
- NOS grips
- NOS sidestand from an SS800 (20mm longer)
- NOS oil cooler
- genuine 851/888 alloy swingarm was not NOS unfortunately, but was fully restored and powder coated by Bonehead Performance
All hardware throughout entire bike replaced with 316L stainless and titanium; axle, brake rotors/calipers, axle pinch bolts, shock, slave cylinder, all banjo bolts, sidestand, and triple clamps mounted with Ti.
Other goodies worth mentioning:
- STM Italia front & rear fluid reservoirs w/custom machined mc mounts and Tygon hoses
- Oberon fuel cap
- Oberon 2 way billet turn signals
- SSR billet crank case cover
- Speedymoto "flow" clutch cover
- JMT oil temp gauge oil cap
- Motodemic drop in LED conversion with Motowheels carbon fiber bucket
(Replaced Motowheels LED headlight kit which was a Truck-Lite with billet adapter ring. Excellent unit but lacks the fit and finish of the Motodemic/JWS EVO II by a mile)
- Vizi-Tec Supanova
- CNC Racing billet headlight mounting collars/U-bracket delete
- Motowheels billet valve covers
- Motowheels custom alloy battery box
- Motowheels billet steering stem nut
- Custom FrenTubo Hypermotard oil cooler lines (routes under front cylinder, much cleaner)
- Cox Racing oil cooler cover
- Zeta levers
- Corsair billet ignition key cover/shroud
- Corsair billet axle/chain adjustment plates
- Corsair billet frame and tail chop plugs
- Sargent seat
- Rizoma carbon fiber heel guards
- Speedhut all in one clocks w/GPS speedometer, tach, and shift light
- Ducati Performance alloy fender
- Ducati Performance alloy nose fairing
- Motowheels billet exhaust collets
- Competition Werkes fender eliminator shortened to delete plate light mount, rewelded, and powder coated by Bonehead Performance
Future mods short list:
- update shifting parts; return spring, retainer plate, gear selector fork to Corsa spec components and add Factory Pro shift detent micro bearing upgrade.
- Redfox adjustable cam pullies
- Ferrodo brake pads
- Nichols motor mount studs
- Motogadget M-unit + complete rewire
- Tekarbon shorty rear carbon hugger
- SSR billet cam covers
- Ricks MOSFET R/R
- Ricks starter
- Shorai battery
- FrenTubo hoses
- Rizoma rearsets
NOS factory parts
- NOS switchgears
- NOS grips
- NOS oil cooler
- Oberon fuel cap
- Vizi-Tec Supanova
- Zeta levers
- Sargent seat
