1 - 8 of 8 Posts
2002 900SS
1992 900SS...There's no other way to explain it. I'm going down the road, 65 to 75mph. The bike starts to bog like I'm running out of gas...all the way down to zero. I pull over. It starts right back up, and away I go for a few more miles...then the same. It always starts and revs just fine. Then, the previously mentioned happens. I've spent over $1000. I need this forum's best and brightest. Thank you.
I don't know what your initial grand went to...but typically a second diagnosis points to loose wires... that said...is it random...is it only between a certain speed...did it rain...under load...in the morning...engine temp...do you have to turn the key off and on or does it start right back up...does the headlight stay on during the event...is the tank full or empty..is there debris in the tank...can you repeat it...
Your last quest is a danger..
sure he can..
Ha ha..
But I’m confused. Subject line 2002, text body .. 1992...
Both supersports... so they are all the same I guess..
Didn’t try hard to find it but where is edit????
Didn’t mean subject line... meant the bike model beside OP name
Sounds like tank venting. Try opening the filler. Also carry a spare plug with you, and after it happens quickly put it in a plug lead with it laying on the cylinder, and turn the bike over to check for spark, in case something is heating up and failing. But my money is on venting.
2002 900SS
Discussion Starter #7
I did the venting. Opened the tank while driving... still the same. Changed out the little breather valve. New fuel filter. New fuel pump. Adjusted the carbs. A new belt. Not that the belt had anything to do with it. Still the same...that was the $1000.
My 96 M900 used to do something similar, which always felt like a fuel starvation issue. Mine has a soft 'U' shaped fuel line just after the fuel filter to the vacuum petcock, and I think it was collapsing from the fuel pump. Being frugal, I found a screen door spring that would just fit inside the line, pulled it through so that it was long enough to keep the line round throughout the bend and reinstalled. I haven't had the issue even hint at coming back since then. If yours has a vacuum petcock as well, check to see that it's working without any issues, too. YMMV - good luck!
1 - 8 of 8 Posts
