I am un-familiar with the BDST 38 B73 Mikuni's on my 1995 900 Super Sport. The two ports seem un-balanced (one opening more than the other). I would like to check this with a vacuum gauge. Is this possible? I have not gotten into it yet and would like some input. Most carbs have an idle adjustment and above idle adjustment. Is this possible and where are the adjustments. Thank You
Sounds like you want to sync the carbs. There should be an adjustment screw somewhere on the linkage for this. There should also be some ports downstream of the carbs on the intake to hook up a vacuum gauge.
The adjustment of the idle and throttle sync face forwards.
They are accessed under the steering head, where the cables meet the linkage.
From memory the most forward one is the idle setting, the further in one is the throttle sync. Adjust this one with caution.
Bear in mind that the carbs do not usually need much adjustment on these.
Idle and low-speed running often are symptoms of poorly adjusted valve clearances. I would check those before altering the carburation.
I serviced these models for many years, and rarely needed to alter carburettor settings.
The best improvement is to replace them with (non-CV-type) Keihin FCRs.
The other is to replace the weak stock coils with stronger Dynas or Bosch 40Ts.
A careful reset of the valves and a set of coils usually brings them to life.
