No video...but I'm here to help...Anyone have link to a video or easy to follow instructions to replace my timing belts?
Likely using the tooth counting process. Can’t seem to find a video.
thanks
That is NOT the tool you want!!If you have access to a 3d printer or a friend with one and some beer money.....
Ducati cam belt tool by Borealis3000
Useful little tool which blocks the gears for the rocker arm under pression (Vertical cylinder!) when changing distribution belts. Made of ABS. Tried on a 851/888 ok. Apparently the space between gears is slightly different on other Ducati 4 valves. Note that this tool isn't mandatory. Just...www.thingiverse.com
