My Ducati ST2 will not give more than 4000 RPM!
211 Views 4 Replies 4 Participants Last post by  Shazaam!
Suddenly the Ducati will not work above 4-5000 rpm.
I have checked a lot, but still the engine will not run above 4-5000 rpm. Feel like it does not get gasoline.
I have done following:
-Checked all wire and connections -and spark plugs
-Open the tank and checked pump and filter (new)
-Measured the TPS (throttle control) and it gives 0,8v up to 4,8v at max opening as recommended.
ANY TIP ANYONE?
Regards -Kjell - 2097 - DUCATI ST2
Automotive tire Hood Motor vehicle Automotive lighting Tire
Automotive tire Gas Auto part Machine Motor vehicle
Compression: Not it because it runs. But I'd still check for power loss against book running pressure numbers..
Spark: Not it because it can run up to full advance at 4k.
Fuel: Bingo... weak fuel pump pressure. Cannot meet demand.
Hi my ST2 2003 did something similar by revving up to 3,000rpm then dying, the fault was my reg/rec failing as it would show good volts at idle up to 3,000rpm then drop to 3volts. I have upgraded to a mosfett reg/rec and after a bit of grinding was able to refit it into the airtake where mine was originally fitted.
  • Helpful
Reactions: 1
So get running, voltmeter across the battery, rev the engine, Does it show over 13.8v? 14.4v? Then back to fuel.
