1 - 20 of 20 Posts
I just bought a new 2014 Monster. I have been told by the dealer that you can't get the regular battery tender pigtail attached to the battery because of the battery location and Ducati no longer sells just the pigtail that connects under the seat. They now only sell the $80 tender. Does anyone know of a source to get just the pigtail that has the proper plug under the seat that can connect to a Battery Tender? Thanks in advance for your help!
I've got a pigtail attached to the top of the battery on my Monster 821.
In principle the battery location on the 1200 & 821 is the same.
I know the rear shock is slightly different between the two models, but if this changes the battery cover to that extent I don't know?
Ill add that I just got the Optimate 0-47 Adapter and it hooked up to my battery tender perfect
I have the adapter for the Monster 1200 from Amazon and it hooks right up under the seat and plugs into my Battery Tender and charges the Monster up as designed.
Yes, the gear indicator must be unplugged while charging the battery.
This pigtail is not meant to stay on the bike. It is really an adapter to be kept on your Battery Tender so that you can plug into your Duc's underseat DDA port.
The GIpro DS-series from HealTech Electronics. It works wonderfully. Blue color is the best followed closely by green.
1 - 20 of 20 Posts
