If you have no constructive criticism to offer, KINDLY MOVE ALONG and mind your own business.
:yo:Hello guys, since Denver CO drivers are very bad at driving cos they are always high of the green - :smoking::smoking::smoking:
I mounted LED lights on the fairings to improve visibility and in preparation for the spring and summer riding.
The LED lights are placed under each part of the fairing precisely of the body works so that the lights do not spread out ugly when its turned on.
I also made a switch that controls the led lights to come on or off (the switch has 3 settings, High - which you can see in the fist 2 pictures, low - seen in the rest of the pictures, and off.) I personally like the low led lights.
The wires are on a different terminal connected directly to the battery so that It does not interfere with the manufactures electrical systems. I also install quick disconnected on the LEDs to the fairings so that it can be easy to remove if I need to do a service work.
Let me know if you have any questions or suggestions. Im always open to new ideas.:wave::wave::wave:
