I recently picked up a 2014 Multistrada. Absolutely awesome bike but what is with the all but worthless rear brake? Tried bleeding it, no good. I found 1 thread on this but no answers. Someone please clue me in.
+1I had a 2013 GT. The back brake is a well known problem. Bleeding it by raising the calliper above the highest point of the system will (if you get it right) fix the soft peddle for a few hundred miles or so. People have tried fitting bleed nipples to the abs unit (at the top of the system), I believe in the USA Ducati tried out a fix to the master cylinder piston (or something similar) but all to no avail. I was offered a "soft bleed" under warranty from my Ducati dealer but the tech told me it he thought it was a waste of time (be such a temporary fix). After doing a few bleeds myself I just got used to pumping the rear brake on the rare occasion I wanted to use it. I asked my dealer if Ducati had fixed the issue on the DVT but he didn't know. The cause of the problem (so I heard) is heat from the exhaust in the area of the rear brake reservoir. The design in this area looks different on the DVT. No doubt someone will mention it if it's still a problem.
I've managed to make the rear brake pedal hard like a stone on my 2015 MTS 1200S. Here is step by step how-to. Don't worry, you won't get the rear wheel off the bike.
1. Remove rear mud-guard for easier access.
2. Remove the plastic part hiding the rear brake hydraulic lines.
3. Remove the small, hydraulic line holder piece from the right side.
4. Remove all small black pieces holding hydraulic and ABS lines together.
5. Now you can easily remove the rear caliper, turn it downside up and slide out from the chain side. Hold it as high as possible. Put something thick as your rear disc between pads.
6. Call your wife, sister or neighbor to help you pressing rear brake pedal while you crack the bleed valve. (Won't tell how to bleed, it's as usual.)
7. When it's completed, put everything together.
You won't believe how good the rear brake works.
Please try.
Derin.
What was the model?Someone recently doing a "day one" review of their 2017 (IIRC) said it had no back brake either. No being subjective of course.
