'13 Pannigale has oil dripping from the lower fairing. When I looked closer, it was streaming from the clutch cylinder. I assumed it was the clutch (which was the problem) because I found brake fluid on my garage floor. So I put a new clutch cylinder in, bled the clutch and it works. Not 20 minutes later the same oil leak from the same place. My question is, did I muck something up on the install? Has anyone had this problem and how can I remedy it?
