So i went to start the bike today after doing winter maintenance and the vertical cylinder is not firing. I pulled the plug out and checked for spark which it is and I also sniffed the injector for fuel, which it did. Next I checked for trouble codes and get a P0351. I believe this indicates an ignition coil problem. Bike has new NGK MAR10A-J plugs.
I didn't have time to swap coils and plugs to see if the problm follows. I'm just doing research now to see what else it may be.
I'm just curious as to why I'm getting an ignition coil code, yet when i pull the plug and crank it over, I see spark. Is it possible it's just a weak coil?
Any other suggestions while I search?
