41 - 51 of 51 Posts
Discussion Starter #41
I’m almost ready to get this bike on the road. Having a problem with the right turn signal. Randomly the right turn signal will stop working Along with the “up” button. It seems more likely not to work when the bike is warmed up. From researching online it looks like I might need to replace my dash? Can I replace the dash alone or do I need t replace the ecu and ignition with keys also?
Do the controls work fine when they are not clamped to the handlebar?
Worth starting here - my controls on my monster 821 were a bit sensitive if I over tightened them on the bar. I don't know why - it's a character thing!
Neil
Discussion Starter #44
Can anyone take a look at the hardware holding the steering damper on? The parts diagram doesn’t show much and it seems like the 6m bolt is a bit loose in the 8m hole.
Discussion Starter #45
IMG_5402.jpg IMG_5397.jpg IMG_5401.jpg IMG_5404.jpg IMG_5406.jpg IMG_5390.jpg IMG_5377.jpg
Installed a Chinese fairing kit, fitment was a 5 out of 10 and there were a few dings on the paint. I’ve already dropped a set of oem fairings off at a paint shop. The plan is to register and have the bike inspected with these fairings, and then swap them along with the exhaust, some carbon pieces, the front and rear turn signals and smoked windscreen. The last thing I need is mirrors which are taking insanely long time to arrive.
it's not aero it cools the rear tyre!
Discussion Starter #50
Got the permanent tags, swapped out those Ill fitting Fairings for some oem repainted ones (with titanium bolts), installed full titanium akro exhaust and got rid of the Japanese spec parts. Still have a few more mods to do. IMG_5469.jpg IMG_5468.jpg IMG_5474.jpg IMG_5471.jpg IMG_5473.jpg
41 - 51 of 51 Posts
