1 - 13 of 13 Posts
Hi Everyone,
I'm taking delivery of my first DUC next friday, 2013 Panigale R, a dream come true !
I plan to ride it on the street but also on track days.
I'd like to add a few protection items to help in case of drop or fall (frame sliders etc.) but I'm not sure what/where the panigale needs protection.
Can anyone help me by pointing out which protective pieces are most likely to be "effective" in case of a drop or slide . I'm a 20 year veteran riderbut a panigale noob at the moment...
Please no one post the usual "training wheels on a kid's bike" LMFAO !
Thank you in advance !
Congradulations on getting the 1199R it's a great bike! Nevermind some of whining about 1199R in other threads and Duc forums.
There's not a whole lot out there for the 1199 models yet, but parts are trickling in slowly. I have not used this companies parts yet though, but they sell a whole kit. The S ABS/Tri models should be pretty similar to your R for most parts.
Try:
Motowheels-Motorcycle Performance Products for Ducati, MV Agusta, Aprilia, KTM - Rancho Cordova - Sacramento
BellissiMoto - Exotic Parts for the Beautiful Italian in your life.
Enjoy!
Check out the following:
Woodcraft engine cover
Frame slider
Front axle slider
Tank sliders
Radiator guard
Sato frame-sliders.... but have to notch RG or GB case covers to fit properly with Sato's. or use a half style case cover
Case covers - which ever is your preference
Speedy Moto axle sliders... Front and Rear
DP or cox radiator shield....few other brands out there just as good
I'll post a pic for you in a few hours
The axle sliders are similar as before. The main problem is going to be the tank. There isn't really a frame slider out there that will offset the possibility of the tank hitting. . . I think r&g or someone else makes a carbon stick-on that will fit around the panigale tank, but probably only the non-R. The R tank is a bit different so not sure if it will fit the new R.
Discussion Starter · #9 ·
Are the axle sliders necessary ?
I ask because I use pitbull stands and I kind of need the rear hole the axle sliders cover for my stands and transport...
Ever fall ?
Rear ok ?
Not on the 1199 but the CF cover on my 1098 saved the swingarm from damage.
I tried using the sliders on the rear on both my 996R and 1098 but always took them off to put them on a stand and to trailer (using the Pitbull set-up). Eventually forgot to put them back on...
-M
1 - 13 of 13 Posts
