I installed the power commander and quick shifter at the same time. i refitted all the parts and went for a test ride. went about 15 miles normal riding and every thing was great. I then decided to test this thing out. I went 100% throttle threw 1st gear then quick shifted into 2nd at about 8500rpm. then at about 9000rpm in 2nd gear (front tire at about 2 oclock) i heard a pop as if i hit the rev limit and the engine light came on with code 13.1. it is now only running on the front cilinder. The code 13.1 shows problem with vertical injector. im running the full term. system map.
please help
please help
