Anyone purchase a center lift/stand and not able to get your bike to set straight up and down? I purchased one for my 97 748 along with the correct pin kit and can’t get it to set level no matter what I do.
Sent from my iPad using Tapatalk
I must say I've never seen one of these.
My guess would be the pins would have to go all the way through the frame to set straight....but you cant do that obviously. I cant see how it would set straight. :unsure:
Does it require removing one of the engine mount bolts and screwing in the lift bolt ?.........maybe?
I cant see it just resting in the holes....it has to mount in order to be safe from falling off.
Discussion Starter #6
I got it fixed. It turned out that the adapter that SV Racing sells is shit. I purchased an adapter from Bursig and replaced the 10mm engine bot with a 14mm bolt from a 916 and now it works perfect. After playing around with a few adjustments it now is stable and sits perfectly straight.
