When it hit that revs the engine goes off, doesn't backfire or anything.
I have to restart itWill it fire up again if you roll off the throttle or do you have to re-start it?
Why would it have come out of calibration?I'm going with the crank position sensor(CPS). There are shims between the sensor and the casing, possibly two, which set the gap. Try removing one to reduce the gap.
I have no error codes, that is why I'm not sure what could be the issueAfter said incident turn the key off, hold down the left button and turn the key on. Big EF1 will display. Any error codes will show on the lower part of the display.
Yea, ya just gotta go through the usual stuff, battery, charging system, connectors first. I doubt something magically failed, its probably something loose or WET. These bikes don't like to get wet and any dampness can damage the fuel in the bike (condensation) AND connectors.The bike was running as usual, I didn't use it for a week, then, this happened. The only explanation could be that my mechanic replaced the water pump like a month ago, but after that the bike was running fine with no issue, until now.
